TwinTurbo.NET: Nissan 300ZX forum - Re: bad splice or injector (not the splice).....
jmoept
on May 15, 2008 at 12:02 AM
bad splice or injector (n/m)
posted by ali300zx
on May 14, 2008 at 09:36 PM
I made triple sure the splicing was good to go. I took off all the tape and made sure all cables were good. The connectors are spanking new. I did notice the old cables had some green residue on it. Why? How can i check to see which one is bad?
Idle power lost after changing fuel injector connectors.
jmoept
14:14:40 05/14/08
Re: Idle power lost after changing fuel injector connectors.
txq45
16:12:39 05/14/08
Re: Check codes
jmoept
17:54:07 05/14/08
Easy
93DemonCar
18:32:59 05/14/08
and the code is..................
jmoept
20:33:19 05/14/08
ali300zx
21:36:00 05/14/08
Re: bad splice or injector (not the splice)..... -
jmoept
00:02:39 05/15/08
Re: Re: bad splice or injector (not the splice).....
jmoept
00:26:47 05/15/08
If you haven't fixed it by November...
rojoloco (San Diego)
11:52:32 05/15/08
jmoept
00:33:29 05/15/08
OHM the connection from the ECU
93DemonCar
09:24:47 05/15/08
That green residue is corrosion
spicyZ
09:54:06 05/15/08
Re: That green residue is corrosion
jmoept
11:53:49 05/15/08
